taking out rear seat, at least bottom
  • rwh11385
    lance_entities
    • 18403
    What kind of procedure is removing the rear seat.
    Pull up on it, or screw, bolts, etc?
    Just a quick few steps. thanks
  • Rob
    • 8166
    BEERTECH
    • rwh11385
      lance_entities
      • 18403
      sweet, just what I wanted.
      if anyone else knows besides Josh, is the fuel tank seals (whatever) located just under the carpet? fuel smell, wet tank (only when tank is completely full).
      • Rigmaster
        • 3464
        Once you get the rear seat bottom out, you'll see a sort of oval metal cover plate, painted black, with ~8 phillips head screws holding it down. Remove this plate, and you'll have access to the top of the fuel pump pickup. It could be the o-ring that seals the pickup to the tank, but I'll bet it's one of the hoses that run to the tank or the pickup- probably a vent hose- they get old and crack- and when you fill up the tank, they leak.
        Another possibility (happened to me), is the vent hose where it runs under the right rear wheel well- there's a long narrow metal cover plate that protects the vent hose (look behind the wheel- in the back of the wheel well). On my car, the hose was chafed by this cover, until it wore thru the hose, and it would leak, only when I filled the tank REALLY full.
        Bret.
        • AdamF 88iS
          • 2051
          Theres only 4 screws on the cover. Pull up the grey foam stuff and you'll see it on the passenger's side.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • VtwinVince
            • Oct 2004
            • 26
            While you're in there, you might want to check out the build document under the seat, which has details on your car printed on it.
