Finally got her started again, now its running rough
  • Tbolt
    • Nov 2007
    • 1165
    So I swapped my fuel pump, fuel filter, and fuel pump relay with brand new OEM parts. Good news is I can get it to start (although it doesn't always start but it starts most of the time) but the bad news is it is running wierd. I took some videos maybe you guys can tell if its the injectors or starter or something else.
    I think I am going to sea foam it, and maybe replace the injectors.
    CRANK YOUR SPEAKERS UP THE AUDIO IS LOWW
    also, the videos are not popping up for me yet...give them a little to propogate
    this first video it starts up nicely but with the check engine light on(was never on before I started having problems) but it goes off after it idles for a minute...notice it idles fine and revs fine.
    now here is what i dont understand, this video was 30 seconds later and it starts running rough and idle bouncing over 1k...how does it go from nice clean running to running awful and sounding like its going to cut out?
    when i replaced the fuel pump i looked in the tank and scraped the bottom with a clothes hanger and i did see SOME sediment at the bottom, but it was very minuscule and I could still see most of the bottom of the fuel tank.
    possible suspects: injectors...but if they were clogged wouldn't it be constantly running rough or not start at all?
    ICV...don't think so...even when rev'n ill notice it to stagger
    ECU - ???
    head is blown?
    battery/electrical - ?
    this is becoming a pain in the ass
    Tbolt Division
    All I'm saying dude is that bird law in this country...it's not governed by reason.
  • Wh33lhop
    • 11705
    Dude, not only did you use the wrong embed code, but you posted the same video twice.
    paint sucks
    • Tbolt
      • Nov 2007
      • 1165
      ehhh whoops
      fixed though
      Tbolt Division
      • Tbolt
        • Nov 2007
        • 1165
        any ideas?
        Tbolt Division
          You probably have intake leaks.
          • Tbolt
            • Nov 2007
            • 1165
            consult the manual on how to diagnose intake leaks?
            Tbolt Division
            • BDK
              • Jul 2008
              • 684
              as far as your check engine light, did you notice that it stops blinking when you step on the brake pedal?
              • Tbolt
                • Nov 2007
                • 1165
                nope, it goes off when im rev'n in the video.
                Im getting m50 injectors I really think mine are clogged or there are intake leaks. How can I test for intake leaks though...maybe just replace the boot and a few hoses?
                Tbolt Division
                • e30:)
                  • 728
                  you can spray carb cleaner on the boot, if there is a leak it will rev up when you spray the leak
                  • Tbolt
                    • Nov 2007
                    • 1165
                    well whats happening now is it will start right up and die. I am replacing the injectors with m50 ones (why not eh) and if that doesnt solve my problem ill check for intake leaks. Sooner or later im replacing the boot with a new oem one, mines looking ratty.
                    thanks though =p
                    Tbolt Division
