Uv dye on a/c compressor bracket. A way to pull a vacuum on a/c compressor only?
  • clydesdale
    • 631
    I believe my a/c compressor is leaking. I put uv dye in the system and it is all over the bracket for the compressor, but the compressor itself and the hose fittings do not seem to have oil and dye on them. I would like to vacuum test the compressor to see if it will hold. Is there a way to do that? Any idea what I would need besides the vacuum pump? Thanks
