Gas/Temp Tauge, Tach, and HVAC Controls
  • Mpoweroo1
    • 18
    Yesterday, as I was driving, Gas/Temp Tauge, Tach, and HVAC Controls just went dead. I was using the A/C and it just stopped as if a fuse blew. Well upon revision, I can't seem to find a blown fuse! The lights for the A/C wont even turn on.
    Any help would be greatly appreciated. TIA
  • Goya20
    • 325
    i had the same problem check fuse number 10 in the fuse box. What year is the bmw
    • Mpoweroo1
      • 18
      Sorry, it is a 91 318i.
      I checked the fuses and they all looked good. You think I should replace it anyways?
      • Jean
        • 18228
        Test the fuse, not just inspect it visually.
        • Mpoweroo1
          • 18
          Thanks, I am a little confused as to why the guages went out and the A/C controls too? Are the paired to a similar ground?
          • romeomike
            • Apr 2009
            • 71
            Can't answer the why question, but the cluster and AC controls both use ground point G200.
            Search for e30_91_modified_090512.pdf as it is the most complete electrical troubleshooting manual (ETM) for the 91 model year. The ETM is very helpful with schematics and a series of tests for troubleshooting the AC system.
            On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
            • Mpoweroo1
              • 18
              Thanks for all the help guys!
              I replaced fuse 10 and 20 and took out all the relays, cleaned them up and made sure they were seated. Everything is working like a charm!:D
              • Goya20
                • 325
                np
                • kwblah
                  • Mar 2007
                  • 196
                  I have this same problem... already changed fuse 10, 20, and 21. Fuel/Tach gauges and all hvac functions still not working.. what else could it be?
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    Si board batteries
                    • kwblah
                      • Mar 2007
                      • 196
                      Originally posted by E30_fiend
                      Si board batteries
                      So i get that this would affect the gauges in the cluster, but why would it affect the hvac functions?
