Can I fix the odometer myself?
  • DaN
    • 1265
    The odometer and trip counter aren't working on my 85 325e VDO gauge cluster.
    I've heard they have some gear inside that commonly strips out. Is it possible to obtain the parts to fix this? Do they make a repair kit? II'd rather get the parts and do it myself, than send it out.
  • arnoldgtr
    • Mar 2004
    • 153
    VDO's have three gears that commonly break. You may as well change them all...otherwise, you'll be taking it apart again. Buy the three gear set here.
    John
    88 ///M3 Cinnabar
    84 318i Black
    • DaN
      • 1265
      Cool thanks.
      Wow they really bank on these plastic gears, $25 each? lol
      It doesn't say which bmw the gears are for, I can assume its for the e30?
      • Sean
        • 5793
        You can always just find a junker and steal that one?
        - Sean Hayes
        • Jand3rson
          • 37587
          And replace broken parts with worn parts?
          • arnoldgtr
            • Mar 2004
            • 153
            I've pulled a dozen clusters from junkyard E30's and I have yet to find one with good odometer gears.
            I believe the 3-gear set from odometergears.com was less than $75.
            John
            88 ///M3 Cinnabar
            84 318i Black
            • hotghias
              • Jan 2004
              • 148
              :) i found one with good gears, but it has 20k more miles than my car, so i have to wait a year or two to put it in.
              • PanamaE30
                • Oct 2004
                • 768
                $65 when you buy them together.
                1988 325iC - "Betty" - Daily Driver/Project Car.
                1993 318i - "The Golden Dream" - Dad's Car.
                1995 318ti - "Hellrot" - R.I.P.
                • Sean
                  • 5793
                  No, not take the gears. i meant take the odo from a parts car and use that til is dies. That's what I plan on doin when mine stops working.
                  - Sean Hayes
                  • 318driver
                    • 1714
                    ok, so i just found that one of my gears is busted, its the smallest one, Would this be the problem for my speedometer not working as well as the odometer.
                    Thanks.
                    90 325is
                    IE stage 3s and refeshed m20....
                    • AdamF 88iS
                      • 2051
                      Thanks.
                      No. The gears only run the odo.
                      FWIW, the reason these gears break is because somebody along the line had pressed the reset button while the car was moving. Make sure you're stopped when you press the button, and when you do press it be gentle.
                      Adam Fogg- '88 M3
                      Common sense- It's the new 'gifted'
                      • 318driver
                        • 1714
                        got my hopes up for nothing lol. Atleast my odo will work, or will it since my speedo dont work? Oh well. Do the SI batteries control the speedo at all? or is it something else, because the rest of the cluster works, only the speedo doesnt.
                        Thanks.
                        90 325is
                        • arnoldgtr
                          • Mar 2004
                          • 153
                          If the speedometer and odometer both don't work, check the sender on the differential.
                          An internet myth.
                          Certainly not true in either of my own cases. I never reset the trip odometer at all.
                          If you inspect the gears, the combination of heat, age, and the grease used to lubricate them turns them to a jelly-like substance. They finally just disintegrate.
                          John
                          88 ///M3 Cinnabar
                          84 318i Black
