Another Cluster Problem...
  • BigBumperNick
    • Apr 2009
    • 148
    Ok, so today my gas, temp, and mileage gauge went dead...
    It was a fuse. Well I replaced the fuse and all was well. Then the fuse blew again. So it must be a short or something somewhere...but where? Has anyone had same issue and where was the short if that was it?
  • REVHARD05
    • Sep 2005
    • 250
    the nut on the back of the cluster their are one on each side, sometimes they get corroded and dont make good contact..... just my guess:???:
    • clavinZERO
      Hella sick E30
      • Mar 2004
      • 2027
      Just out of curiosity, does it blow as soon as you go into reverse?
      "BMW Style 32 Poster-Child"
      HTTP://WWW.CLAVINZERO.COM/e30-5-lug
      **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
      • Goya20
        • 325
        yea does it blow in reverse, cuz the reverse wire may be pinched against the chassis. Check under the shift boot and the wire is there check if it getting pinched between the rubber bot and chassis. I had the same problem. Nothing a lil electrical tape cant fix
