Fixed.
revving up on its own?
Originally posted by Need4Speed1299 View PostI have an 87 325e with a new ICV. Once the engine gets warmed up and I drive it around for a little bit, it decides to rev up to about 4k on its own. Once i drive for a little bit more it will go back to normal. Its almost like cruise control except it kicks on by itself and doesnt turn off until it cools off a bit. Also my car is starting hard, maybe thats related?
I don't know what to tell you, mine just kind of fixed itself. I'm not sure if we have the same exact problem, but I think it's pretty close.
You have a new ICV, which means that there are three possible causes of this problem. One would be intake leaks, another would be a bad idle control module (ICM), and the last would be a sticking throttle cable or throttle body. With the other symptom being hard starting, the chances of intake leaks being a player is very high. The definitive diagnostic for intake leaks is to have the intake, crankcase, and evap control system smoke tested.
After eliminating intake leaks and a sticky throttle cable/body as possibilities, the ICM becomes the prime suspect.The car makes it possible, but the driver makes it happen.
Mine did this when I accidentally plugged into the wrong coolant temp sensors. What should have been plugged into the blue, it was plugged in the brown. When the car warmed up, it stayed at 4k idle... I dunno if this'll help tho...
'89 325i - Totaled... good bye my love...
'87 327i budget stroker - SOLD!!!
'92 240sx - ca18det powered drift toy - SOLD!!!
'89 325i - coupe - NEW daily
'96 Audi A6 Quattro- Grocery getter/baby hauler
'99 Busa - weekend wheelie monster
Originally posted by emi325i View PostI had a piece of plastic break off and fly into the throttle body. It did the same thing.. it would accelerate on its own from time to time until the plastic piece made its way into cyl#6.
Originally posted by jlevie View PostYou have a new ICV, which means that there are three possible causes of this problem. One would be intake leaks, another would be a bad idle control module (ICM), and the last would be a sticking throttle cable or throttle body. With the other symptom being hard starting, the chances of intake leaks being a player is very high. The definitive diagnostic for intake leaks is to have the intake, crankcase, and evap control system smoke tested.
And on a cold morning etc. I can make it go away by getting the car cool again, but once it pops above the blue area on the temp gauge its back into the climbing high revs...
Originally posted by Snowmann View PostWhere is this ICM? I've got a 173 ecu, brand new ICV, brand new coolant temp sensor, and the engine was just gone through and has all new gaskets etc... I checked the notorious spots for air leaks and I've got nothing... Any help would be appriciated... In my case I'm thinking it HAS to be electronic related as it does it immediatly after coming out of the cold start-up loop.
Having this happen when the DME shifts to closed loop mode would suggest an intake leak, bad O2 sensor, or bad AFM (given the parts recently replaced).
In addition to the obvious hoses, intake leaks can be from:
1) intake manifold gaskets
2) injector seals
3) evap control system
4) dip stick o-rings
5) oil filler cap seal
6) valve cover gaskets
7) oil return tube seals
8) brake booster
A smoke test of the intake, crank case, and evap control system is the best diagnostic for intake leaks.The car makes it possible, but the driver makes it happen.
Well I will say, that this was a 153 car, I had the surging idle problems back in the day and got a 173 ecu to remedy that.
The car ran fine with the 173 ecu, and now after pulling the engine I've got this problem...
I've also got a 1222 code, and my A/F ratio gauge is showing an extremmely lean mixture at idle...
I'll have to probably find someone with a smoke machine to do this...
