Hi,
Last week, I posted a thread regarding the fact that I am having toruble with the tach and clock not working. It all started after working on the wiring for ly left tweeter. But that was all that I touched.
Heres the situation:
I found that the PCB (motherboard) had a burned trace between pin 2 on the blue connector and 23 on the yellow. This is the wiring for the constant power to the clock. I repaired the trace, and continuity everywhere on the boards was fine.
Today I went to the car, connected the three harnesses to the cluster. Immediately the trace burned where I had repaired it. I fiddled with it a bit, and got continuity again. I verified voltage on pin 2, blue connector (12V in), and it was 12.25, same as the voltage at the fusebox. I reconnected everything, and it burned the trace at a second spot on the PCB.
Thinking it was the PCB that was bad, I took a larger wire and jumpered from the voltage input (pin 2, blue) to constant to the clock (pin 23, yellow). Immediately fuse 21 blew. Thinking that I may hav e bridged a connection causing a short, I replaced the fuse, and carefully tried again. Once again it blew fuse 21.
So let me get this straight... fuses blow when too much power is flowing through, indicating an abnormality or overload. Chances are that the PCB trace is a far finer wire than what is in a 7.5A fuse, so it blows first. When the PCB is jumpered, then the fuse is the next weakest wire, and it blows.
What would make it blow? I know it is somewhere between the pin 23, yellow connector and the clock. This happened when the clock was disconnected, so the clock cannot be considered at this time as the culprit. Where does the wire that goes from pin 23 on the yellow connector go to? Does it only supply continuous power to the clock, or does it have other functionality?
Judging from research regarding the yellow harness (from the multitude of writeups on OBC retrofit), it seems that the connection between the yellow instrument cluster connection goes only to the clock. I never messed around in that area when fixing my tweeter.
Any suggestions on what to do now? If I was to have the harness replaced, is there anything that I need to know?
Also, the tach still doesnt work, and the SI lights remain illuminated (change betwen 4 and 5 lights, and inspection illuminated). All connections were good, and I verified their traces to connectors on the mainboard/SI board. I did not see that the trace that I was burning had any relevance to the tach power, although A2 (pin 2, blue connector) does apparently feed power to the SI board. Since my SI board batteries are OK, and would you guess it is themainboard that is causing its problems as well?
Thanks very much,
JMH
cc: roadfly
Thanks very much,
JMH
cc: roadfly
