So, I had to replace my starter in my '91 325. I took the intake manifold off and everything else the Bentley suggested.
The Bentley, however, does not give a good picture/instructions for the 4th wire that my '91 has. It's solid black and I thought it went on the smallest stud on the starter. The Alternator and battery wires go on the positive, the ground strap on the other large stud and the black and yellow wire in the stud on the bottom if the starter is oriented the way it is in the car.
The problem I am having is that I have no spark. The starter cranks no problem, just no spark. No spark at the coil and no power to the coil.
It had spark before I took everything apart to replace the starter.
I did some searching and my crank position/cylinder ID cables are plugged in correctly. I unplugged and replugged everything in just to make sure it wasn't a loose connection.
Ideas? Again, I am not sure where the small black wire goes and that could be the problem.
Thanks in advance.
Thanks in advance.
