Can you swap relays?
  • caffeinatedsoap
    • 360
    Can you swap relays from an e36 into an e30. My car is dead and I think it is a relay as it won't crank at all and the battery is good.
    I have an e36 m3 that runs well I was wondering if I can yank relays out of it to test in the e30?
    1992 318ic
  • dranttna
    • 127
    if your still looking for an answer to this, yes all bosch relays are the same just make sure it has the 87a post if it needs it, i dont think the e36 uses an iso relay but it wouldnt fit anyway so you should be fine.
    325es/24v's/20psi/meth injection/
