Convertible Electrical trouble
  • Don Stevens
    • Aug 2007
    • 368
    Where is the circuit breaker/fuse/relay for the lectrical top mechanism on a Vert? I can't find any info even in the Beently manual.
    Thanks in advance
    Don
    Discounts to all R3VLimited users on Amsoil products www.tampabaysynthetics.com
  • nadodude111
    • Jul 2009
    • 432
    there is no fuse or relay for the top. only the microswitches on the actual motors. you need to adjust the orange screw on the lid motor until you hear clicks, stop when you hear the clicks and test the motors thru the switch on the dash.
    1992 325i Convertible
    • Don Stevens
      • Aug 2007
      • 368
      Where is the motor? Trunk? Right? Left?
      • Stevie30
        • Apr 2007
        • 1534
        Maybe this will help. http://www.e30ic.com/powertop.htm#realignment
        1991 325ic and 1991 318is
        • nadodude111
          • Jul 2009
          • 432
          you have to take the trunk lining off. once you take it off you can see the motor right in the middle.
