Driveshaft
  • D-rock
    • 714
    Driveshaft
    Yes yes i know another thread on it! BUT i havnt found what i need.
    I have an e30 diff, e30 m3 driveshaft and e36 tranny. I have everything in and ready. But i cant find a yolk that will fit!!! Any info please!
  • D-rock
    • 714
    anyone?
    • flyboyx
      • 8371
      you might need to explain the problem a little better, but i am assuming that the output flange on the e36 trans is a larger diameter than the flange on the e30 driveshaft. assuming this to be the case, you can buy a drive shaft from an early 87 eta. it has the right diameter to match your e36 trans. another solution is that you might be able to swap the output flange off of an e30 trans to match what you already have on your drive shaft. btw, those are some bad ass style 5's i would like them even better if you painted the basket weave a darker color to match your car.
      Gigitty Gigitty!!!!
