I been getting the 1223 code... I haven't checked the resistance of the plug yet tho because i don't have an ohm meter.
I pulled out the fuel rail and took the connector out and looked at it... its pretty clean... not messed up or dirty... but ran into some issues because I want to replace the sensor and see if it helps the cold starts and low temperature coolant. I changed the other plug that sends the temerature to the gauge already like 4 months ago. I found out the problem is cold starts. If engine is cold the idle bounces when I release the gas. Once the engine is warm and up to operating temp it idles like normal.
The sensor is suspose to be a 2 prong plug but for some reason it is a 3 prong...
Does anyone know the part number for this plug? I want to replace it and I checked on the ETK and nothing comes up. I even went to the dealer and brought a picture and they can't identify the part. It says 350 bosch on it but no part number.
This is the plug its suspose to be:
Why would the previous owner change the plug to this type and have 3 wires to it now?
1989 E30 325i, 5-speed Manual
