Does anyone know if some bbs wheels off of a 1989 honda accord could fit a 1989 325is? I've been looking around the net and I can't seem to find the information.
Could these fit??
Could you be a little more specific? It helps to know things like offset, centerbore, bolt pattern, and especially wheel size.
-Ted
I don't know any of that stuff, I was wondering if someone knew a website that would tell me all of that information for an '89 accord.Originally posted by SlammedE30Could you be a little more specific? It helps to know things like offset, centerbore, bolt pattern, and especially wheel size.
-TedJamie Webster
'89 325is - sold :(
'96 Miata - sold
'01 M5 - sold
'02 Civic Si
Offset- can be corrected with spacers
Centerbore- mid-90s Civics had a centerbore of almost 10mm more than E30s, so I'm assuming an Accord wheel would "fit" over an E30 hub, probably with plenty of extra room (requiring hub centric rings)
Diameter- if it's designed for an '89 Accord I'm guessing it's not going to be too big to fit in E30 wheel-wells
Bolt pattern - I believe a lot of older Honda's had the 4/100 pattern like E30s
seems like it would work.
one idea for finding out specifics would be to look up the available wheels for '89 Accords on tirerack.com, then call or email and ask for the specifics (centerbore, offset, etc)Comment
civics and crx's have 4x100, accords and 4 bolt preludes are 4x114.4Originally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
