Holds straight most of the time but occasionally begins to shake erratically. Not sure if it makes a difference but its an e28. Hypothesis's appreciated.
Intermittent front wheel vibration?
- " Ill Never again argue with an idiot. They bring you down to their level and try to beat you with experience."
http://www.flickr.com/photos/13617577@N04/Tags: None -
Could be worn front suspension parts, worn struts, out of balance wheels, alignment, or a combination of those. The first task would be to inspect the front suspension and replace any worn parts, then have an alignment done and the wheels checked for balance.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
Appreciate it. Will do.- " Ill Never again argue with an idiot. They bring you down to their level and try to beat you with experience."
http://www.flickr.com/photos/13617577@N04/Comment
