My passenger side power window has started making a terrible noise lately.
It mainly happens when it is going down and it sounds like maybe the gears inside the regulator are grinding. I took out the window to remove the tint and thought I have a listen and find where the noise is coming from. I can't tell if it's coming from the regulator or the wire moving through the track(not scissor style). Is this a common problem? Should I just replace the regulator and see if that fixes it? Thank you for your help!
