Well my clutch / clutch pedal started feeling funny last night, I have searched high and low about issues relating to the clutch master slave failing and causing the pedal to not return, the only way mine doesn't feel the same way is the fact that my clutch will always return all the way up but starting last night the clutch return doesn't have the same pressure against my foot as normal. If i press the clutch to the floor, and no matter how long i hold it there, if i release my foot the pedal will jump straight up so I don't feel like its hydraulics related. When I pump the clutch pedal with the car turned off there is a squeaking noise coming from under the car. Mind you my car has well over 300k on it and I have no idea how old the clutch or transmission are. My throw out bearing has always made a dry sounding spinning/raddling noise and if I recall it would go away within the first inch of pressing the clutch in and now the clutch seems to engage closer off the floor than normal and the throw out bearing doesn't get quiet until closer to the floor now. Also the clutch return seems kind of notchy, if I slowly release the clutch it feels like its grinding against stuff on its way back up. The clutch still grabs fine.
Any thoughts?
Any thoughts?
