Tranny issue
  • tranceguy
    • Aug 2004
    • 139
    Tranny issue
    I'm having an issue with my tranny. When it was out of the car, the tranny would shift into every gear fine and spin fine. Now that it's mated to the engine and in the car, all I can do is select 1st and 2nd gear. But I'm doubting that it's actually SHIFTING because when I drop it into neutral, I can't spin the output shaft. I can't move the shifter to the 5th or reverse gear position. I can push it to the right like you would to select 3rd or 4th, but I can't put it in either of those gears. Anyone have any ideas as to what's going on?????
    VANOS FOR LIFE MAING
  • rs4pro3
    • 5808
    Did you slide the tranny on in Neutral? if not try pulling it off and put it into neutral then slid it back on.
    Hopefully that tranny works out for you.
    85 325e 2.7 ITB'd stroker
    • tranceguy
      • Aug 2004
      • 139
      99.9% positive I did. Damnit. I REALLY hate to yank the engine and tranny back out. :(
      • tranceguy
        • Aug 2004
        • 139
        Are there any special tools I'd need to pull the back casing off and take a peek inside?
        • rs4pro3
          • 5808
          ground down 30mm socket, Why do you have to pull the engine?
          • tranceguy
            • Aug 2004
            • 139
            Because it's an m50 and there's little to no room. I'm going to go back over and scope things out.
            • rs4pro3
              • 5808
              Ba, Quite complaning put an m30 in then you'll know what no room is
              • mikeedler
                • 6707
                I cant see what putting the trans in neutral would have to do with anything when installing it? am i missing something?
                • rs4pro3
                  • 5808
                  I don't know my 318i gave me that problem when I put a new tranny on, I Installed it in First gear, Maybe a selector fork is bent or something.
