I'm right in the middle of attempting to change my engine mounts. I've been following the 101 projects book on this project (which they describe as "couldn't be easier", btw) and my motor seems to disagree with raising the full 4" needed to get this mount in. I have a jack under he oil pan with a piece of wood between the jack and the pan.
I'm doing them one at a time, FWIW. I got the old pass side mount out, but it was compressed enough that I was able to slip it out with the engine raised to this height. The new mount is much taller than the old mount and there is no way it will fit in unless I jack the motor up another 3/4". It's already snug against the firewall, fan is above the top of the radiator, lower radiator hose is getting tight, I can feel lots of resistance with the jack, etc.- I just don't know how much further this thing is going to go before something lets loose.
Should I undo the other mount? Or do them one at a time like this? I don't want to break the pan, or anything else, by raising the motor so high. I'm open to any tips or tricks on this one- it's been a PITA so far, just like everything else I've done on this car! Par for the course.
