The seats in my e30 are manual sport seats for a two door. Unfortunately, when you pull the side lever and try to move the seats forward like they used to (this is a recent problem, the driver side stopped working a bit ago, and now the passenger seat won't work either), they just won't come forward. If I use the lower lever to make the seat back come up and be perpendicular to the ground, then the upper level will bend the seat forward, but only if the seat back is moved up past the point of being comfortable to sit in.
Is this a common issue, and if so, is there a way to fix it?
