Fuse/Wiring Problem?
  • BigBumperNick
    • Apr 2009
    • 148
    Everything worked in my car a couple months ago.
    Randomly one day gas/temp/and rpm gauge's die. As well as air/heat from blowing out.
    A fuse blew...
    I replace it and everything works perfectly again...a few miles down the road, it blows again. It will continue to blow no matter how many times I replace it.
    Anyone know where there could be something grounded out or what's the dealio? Not an expert at this stuff lol. Any help appreciated.
  • badvibrations
    • Feb 2007
    • 447
    Exactly.
    It is unlikely that anything in that circuit is drawing too much amperage to cause that fuse to blow.
    It is more likey that you have a short to ground on the power side of the curcuit.(power touching ground before the load in the circuit)
    Know how to read a wiring diagram?
    Equal rights should be all or nothing, not picked and chosen based on what's convenient for ones personal agenda.
    • txtorquemade
      • 1758
      I have fixed all my lighting and electrical issues R headlight, sidemarkers..etc using this guide.....IT is definitive in it's completness and very helpful.
      sigpic 1987 325is
      • BigBumperNick
        • Apr 2009
        • 148
        I found the issue heh. The wiring going through shifter boot. (I am guessing for reverse lights?) And now everything works without fuse blowing. Just no reverse lights lol.
        • txtorquemade
          • 1758
          Ive heard that wire in the shifter boot is a frequent culprit. Good you found it.
          Did you throw in a SSK while you were at it???....<smile>
          sigpic 1987 325is
          • BigBumperNick
            • Apr 2009
            • 148
            rofl. No, but I need to.
            • badvibrations
              • Feb 2007
              • 447
              Use the diagram?
              It help at all?
              • BigBumperNick
                • Apr 2009
                • 148
                Originally posted by badvibrations
                Use the diagram?
                It help at all?
                Used a response on another forums first and just unplug that wire and it helped so I didnt have to. But if I run into anymore problems I definitely will.
