E brake hande won't go down
  • Court M3
    • Jan 2004
    • 6713
    Has anyone had this problem. Apparently on the M3 back home the ebrake will not go down. It is in the full up position.
    any suggestions welcome.
    Continuous For Sale Thread
    323i s50
  • LowR3V'in
    • 4209
    Does the button press in at all?
    Does it go back any further?
    Is it because the wranchet is stuck?
    • DSchultz325e
      • Aug 2004
      • 1158
      pull up hard while trying to press the button in. that should work unless you mean something different.
      I retired my E30 for now...
      E46 323i
      David Schultz
      • rs4pro3
        • 5808
        my 85 318i did that, on the side of the assmble once you pull the rear center consule off, there is a metal tab that got bent inward and jambed the e-rake lever into place. Not sure if it's your problem, or maybe the shoes have seized in the rear.
        85 325e 2.7 ITB'd stroker
        • Court M3
          • Jan 2004
          • 6713
          Unfortunately I am not home but will pass the info on. Thanks guys
          323i s50
          • rs4pro3
            • 5808
            Here is a picture of the tab, on my 318i it got bent and cuaght under the screw for the parking brake light in the cluster. Once bent back it worked fine.
