Hi,
My right rear caliper bleeds fine, but when I move on to the left rear caliper, nothing comes out, does this mean I have to replace the brake line? My brake system is all fucked up right now, I got lots of air into it the first time because I did not check the master cylinder and I accidentally let it go dry.
Also when I connect the pressure bleeder to the master cylinder and open the bleeder nipple, the brake fluid comes out in a constant stream from the right rear caliper, but I noticed that the fluid level in the master cylinder and pressure bleeder does not go down. Also I found out that one of the hose clamp/brass connectors on my Motive bleeder leaked a bit.
Thanks!
Thanks!
