HELP with air box Question
  • E9
    • Oct 2004
    • 36
    I need some HELP figuring out if an air box out of an '89 325i will fit with out any problems into an '86 es. This is probably a very basic question for somone just not me. Can someone plaese help me out with this. I'm in a jam time wise to get this figured out. Any thoughts are greatly appreciated. Thanks a bunch!!
    I'll sleep when I'm dead
  • mikeedler
    • 6707
    from my experience, some of the airboxes are not interchangable, and some arent. I alway keep the computer and the airboxes together. if you swap both it will work.
    Ive had some that wont even idle, and in 1 case drove great till i hit over 5000rpm, then it would sputter out.
    • Rich V
      • Oct 2004
      • 69
      I do not see how the air boxes and the computer have any compatibility issues whatsoever. Maybe the AFM, but not the air box. There is not even a single electronic component in the airbox.
      IIRC, the earlier model E30's have an AFM that uses a different style of inlet than the later models.
      • mikeedler
        • 6707
        thats what i meant smart guy. air its all part of the airbox assy.
        • rs4pro3
          • 5808
          I believe there are three main non m e30 airboxes, the 318i metal one, early 325e metal box, and the later plastic box.
          If you have a metal 325e airbox you need a metal airbox(you can make a plastic one work just fine)
          basicaly all three airboxes are interchangable. the metal ones have a round inlet, so you just unbolt the afm and slid it off, where as the plastic boxes the afm has a rect. inlet so you have to unbolt the inlet it self directly from the afm.
          85 325e 2.7 ITB'd stroker
          • E9
            • Oct 2004
            • 36
            That's what I needed to know. Thanks
