How vital is the plasitc under the engine?
  • BENdashdash
    Tom is not my friend
    • Aug 2004
    • 2506
    Is that plastic "shield" under the engine important to keep on the car? I don't like having to take it off/on every time i need to look under there, but I also don't want mud or whatever getting in the belts. So how vital is it?
  • rs4pro3
    • 5808
    I pulled it off once then drove threw a big rainstorm, my alternator belt kept slipping and the battery light would come on going up hills, it went back on that evening.
    85 325e 2.7 ITB'd stroker
    • Jordan
      • 12913
      I don't have a undertray on my car, as nothing would fit my front end properly.
      I've never experienced the problem Ely was talking about. Then again I have brand new belts and adjuster brackets.
      I plan to make a complete and custom front undertray when I can get my car up on the lift at work on the weekend. Big sheet of plastic formed to fit with heat... mmm.
      As far as I am concerned the stock undertray serves as a aerodynamic part, and thats about it. You don't "need" it.
      https://mtechniqueabs.com/
      • uofom3
        • Jan 2004
        • 5392
        it helps create down force on the front of the car, or at least reduce lift, and protect your belts from water... that's it, but if you want to replace it i bet you could find one at a wreckign yard for nothing... Jordan, have you tried just cutting up a factory one??? one from a us e30 m3 might have a better fit for your bumper system??
        PNW Crew
        90 m3
        06 m5
        • Rob
          • 8166
          aerodynamic effects are all but useless on 95% of the cars on here.
          BEERTECH
          • Ryan Stewart
            I Love Miatas
            • 8978
            Its much more likely to reduce noise for the most of us.
            Im now E30less.
            • bmwannabe
              • 900
              all mine is good for is collecting oil from my oil leak. then when i park on my g/f's inclined driveway it all spills out and her dad gets pissed. I guess i need to fix that.
              • Jordan
                • 12913
                • T.Dot E30
                  • Mar 2004
                  • 536
                  Mine has been off, for the longest while, too lazy to put it back on and dont feel the need.
                  aerodynamics?? lol like a little piece of plastic is gonna help an e30 out much. the design of the car doesn't help
                  • DaN
                    • 1265
                    i didnt even know they had undertrays, what year did this start?
                    • rs4pro3
                      • 5808
                      It was a very heavy rain storm, none of my other e30's had one and I never had a problem on them.
                      • BS87
                        • 1606
                        Yeah, 1 piece of plastic isn't going to help the whole "Brick with 4 wheels" thing.
                        • Jordan
                          • 12913
                          The stock panel may not help, but I promise you it doesnt hurt.
                          It will absolutely reduce the lift effect at speed. Smoother the air flow under the car the better.
                          • ///M Powered
                            • Jan 2004
                            • 1109
                            which models did these come stock on?
                            <--- doesn't have one and has never had a problem in "bad" weather.
                            • BMW BMXER
                              • 2325
                              Plastic under tray??
                              I don't have one, never did.
                              Sold it.
