Hi to all,
Is there a tool(s) for disconnecting pin connectors from the plastic connector housing? something that can depress the little tongues so i can slip the wire with pin out?
basically, what tools would i need to:
- Be able to replace a broken Idle control valve connector without cutting and soldering (i have a used clipped connector from junk yard)
- Replace my shiffer rubber insulator that the reverse light switch cable passes through (the connector is too large to pass through the hole)
- Replace the female/male pins in the door jam connector with new BMW ones, and crimp them properly
