3rd Gear and 5th Wineing
  • ZiMMie
    • Jun 2004
    • 968
    after couple of donuts in the snow last night. I drove the car to work to day and i notice a wining in the shift lever when the car its in 3th or 5th. It only wines when the car its moving doesnt do it when when its still. am thinkin Tranny oil? wat do u guys thnk?
    www.stancefactory.com
  • Jordan
    • 12916
    Couldnt hurt to drain and refill.
    https://mtechniqueabs.com/
    • ZiMMie
      • Jun 2004
      • 968
      but will that course it to do that?
      • Jordan
        • 12916
        Sure... but topping off the fluid might not help. Old worn gears tend to whine to some degree.
        • Old'n'Slow
          • 436
          Also, if your input shaft bearing was "almost" shot, you might have finished it off. Does the noise go away when you push the clutch in when your sitting still? Also, if it's really quiet while cruising in 4th, you may have bad layshaft bearings.
          Change the lube and watch for metal in the oil!
          Good luck.....sounds expensive!
          • Saul325is
            • 819
            I have the same problem....I just installed a 4.10 and its whining. If any of the bolts were loose between the driveshaft to diff or trailing arm to diff could cause this? The whining only happens when I am accelerating or letting off the gas...If I keep the car exactly at the same RPM's it doesnt whine. BTW, its just a faint whine.
            Saul
            Saul
            01 330ci Daily Driver
            89 332is Auto-x Friend
            95 M3 *SOLD*
            87 325is *SOLD*
            • cahomey
              • Mar 2004
              • 1201
              Saul
              Thats because there is no directional pressure on the gear. The "whine" is the vibration that results from one gear spinning the other.
              "It's like a koala bear crapped a rainbow in my brain."
              R.I.P. Harry Goz aka. Captain Murphy
              "My ride, My ride, she don't beg, steal, cheat, or lie,
              My ride, My ride, and our relationship is classified."
              • ZiMMie
                • Jun 2004
                • 968
                it doesnt wine in any gears (not rollin)unless the car its movin its not u cant here it but u can fell the lever vibrating.
                1,2nd,4, are still good no vibartion. ill change the tranny oil tommorow.
                Funny thin its the vibration its less today.
