copy and pasted from e30 tech not seeming to get a response there. maybe someone here has some ideas
So three problems here.
first and most annoying is that i cannot lock the car by inserting the key in the drivers door. It will only lock the drivers lock but not the other 3 or trunk.
I use the passenger side and it works flawlessly. The car unlocks via either door though
2nd:
I can not unlock the passenger front door when using the drivers side door lock or trunk. all other 3 doors and trunk unlock but not pass. front. this used to be intermittent but now it never unlocks
3rd.
when using the key to lock the trunk and therefore all the other doors it will lock then half a second later all doors unlock themselves. it happens randomly probably half the time they stay locked half the time the pop open again.
the trunk stays locked no matter what though.
Any ideas? could they all be linked to one common problem? Would the cheapo ebay keyless entry eliminate the problems or leave the pass. door lock problem?
car is a 85 318i sedan
2nd:
3rd.
[IMG]http://www.r3vlimited.com/board/
