Putting power to injector for deeper cleaning.
  • NeoMishMoo
    • Jul 2009
    • 448
    I am rebuilding and cleaning my injectors according to http://www.rowand.net/shop/Tech/DIYF...orCleaning.htm . I thought about doing my own e30 write up for r3v but before I can do that I must first finish. All I have left is to clean out the inside with compressed air while putting power to the injector. I cut off a spare harness and now I have a red/white and a brown/white wire. Can I hook up the injector straight to 12 volts with a switch? Can they handle that power or do I need a resistor? Which wire is hot and which is ground (I assume red/white is power but I don't want to make a costly mistake based on an assumption). oh yeah the wires are also numbered 1&2.
    I couldn't find anything on this in the search, do you think a write up is in order?
    West German BMWs, they just don't make the same as they did before the wall fell.
    ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
  • whodwho
    • Jun 2008
    • 1547
    I believe you can overheat them with straight 12v and no fuel. I think I have heard people using a 9v battery, would make it easier to work with and less voltage.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • NeoMishMoo
      • Jul 2009
      • 448
      So red/white wire to postive? Brown/White to ground? Seems obvious but I don't want to screw the injector up.
      EDIT: I've looked through the entire bentley manual and I can't find a wire guide for fuel injection. Grrr.
      Oh yeah and I also looked and all 6 injectors have a red/white wire but 3 injectors have a brown/yellow and 3 have a brown/white. Maybe that helps.
      UPDATE: Pretty sure the red/white wire is positive. Hooked it up to a 9v battery. All the injectors squirted pretty good except for one. It is clicking but not letting air pass through. Hmmm bad injector maybe?
      • SpecM
        • Oct 2005
        • 4531
        it shouldn't matter which way you wire it, all you are activating is a small electromagnet
        1989 cirrisblau-metallic 325i
