Car running 3000rpm at 70mph..is that normal?
  • bmwnoy
    • 58
    Was running if its normal for an auto to hit 3000rpm at 70mph?
    Also, coolant light lites up even tho the reservoir tank is full. Bad sensor?
  • SpecM
    • Oct 2005
    • 4531
    that normal is you have a 4.10 diff, which you probably do
    and yea, sounds like a bad level switch
    1989 cirrisblau-metallic 325i
    • 87-325ic
      • Apr 2006
      • 1198
      sounds like a 3.73 ;)
      • Philo
        Ich esse kleine Kinder
        • 3334
        I'm with this guy.
        -tim
        Originally posted by Jordan
        I like the stance
        • whiltebeitel
          • Apr 2007
          • 2098
          The 4HP22 has a 0.73 4th gear, while the Getrag 260 has a 0.8 5th gear, so they run at essentially the same rpm in their top gear with a 4.10 and 3.73, respectively
          '89 325i track sloot
          '01 530i daily
          -Enginerd
