loose strut?
  • jrobie79
    • Mar 2006
    • 2525
    loose strut?
    I failed an inspection because the guy said my front end was loose.... nothing else specific, so i jacked up my driver side and when i grab the tire at a 3 and 9 position there is a little bit of play when i wiggle the tire from those two points. I shone a flash light on my tie rod ends and the control arm and dont really see any movement there, is it something to do with the strut itself? and if so does the whole strut need to be replaced or is there a cheaper fix? thanks
    1991 318i ---- 308K - retired
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    I think it sounds like a Hub bearingfrom where you say you checked play. What about free play with hands on the 12 and 6 positions?
    • jrobie79
      • Mar 2006
      • 2525
      no free play in the 12 6 position, and you can see the spring/strut kind of twisting back and forth when i push on the 3 9 position, something in the upper area of the strut?
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Sounds like strut mount or broken gland nut.
        • jrobie79
          • Mar 2006
          • 2525
          whats the gland nut? i took the little cap off the top so you can see the ball bearings and what not, and that nut seemed pretty fine, i put a 19mm socket on it and it doesnt spin when i torqued it a little bit, it sprang back to its original position, so im assuming its the mount? thanks
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            the threaded collar that holds the strut in the housing...
            • jrobie79
              • Mar 2006
              • 2525
              thanks man, im pretty sure its the mount, gonna change that up tomorrow
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Why would you change something without being sure, go outside, take the wheel off and fully diagnose your issue.
                • Philo
                  Ich esse kleine Kinder
                  • 3334
                  Eh. Play at 3 & 9 is tie rod and 6 & 12 is wheel bearing. Get it right Farbin. :)
                  -tim
                  Originally posted by Jordan
                  I like the stance
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    SEE^^^ Don't listen to a word I type.
                    • jrobie79
                      • Mar 2006
                      • 2525
                      I recently changed my tie rods about 20K ago, and all signs point to the mount.
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        play at the 6 and 12 position is more indicative of balljoint wear imo.
                        '89 Alpine S52 with goodies
