Were is the pick up for the temp gauge?
  • denisbmwm5
    • 347
    My temparature gauge doesnt work. i checked it and the gauge it self works but now im wondering were the pick up is. On the radiator? or the housing for the turmastat?
  • PanamaE30
    • Oct 2004
    • 768
    It's on the thermostat housing on the M20...
    1988 325iC - "Betty" - Daily Driver/Project Car.
    1993 318i - "The Golden Dream" - Dad's Car.
    1995 318ti - "Hellrot" - R.I.P.
    • george graves
      • 19998
      Do you know if the signal goes thru the ecu and then to the dash? Or just straight to the dash?
      Originally posted by Matt-B
      • PanamaE30
        • Oct 2004
        • 768
        I believe straight through, but I may be mistaken..
        I say this because mine is actually being replaced as we speak.. and my mechanic was saying that if it wasn't the thermostat it was the cluster :\
        • denisbmwm5
          • 347
          Yes i got the m20 but is it both the sancers? And what if i dont have a thermastat the temp wont show???
          • PanamaE30
            • Oct 2004
            • 768
            I've been running without a thermostat for like 4 months. the temp needle just sits dead.
            • george graves
              • 19998
              Well it would move to it's "ZERO" mark when you turn the key, right?
              • PanamaE30
                • Oct 2004
                • 768
                uh nope, sat dead.
                • rs4pro3
                  • 5808
                  it goes threw the engine harness to pin 4 on the c101 then to the instrument cluster
                  85 325e 2.7 ITB'd stroker
                  • george graves
                    • 19998
                    On all e30's with the c-101?
                    • rs4pro3
                      • 5808
                      88 and 87 for sure I'll check on your 89 realy quick.
                      • rs4pro3
                        • 5808
                        Yep same for all, this is for the Coolant temp guage in the cluster and not the Engine temp sender.
                        • denisbmwm5
                          • 347
                          Well my c101 conactor is modifed top fit the 318 harness so maybe thats why im not getting a reading and no the needle doesnt even move then i turn the key. i guess ill have to install a aftermarket cooling gauge and pick up right?
                          • denisbmwm5
                            • 347
                            Oh so it reads from the colant tank thats what ur saying? sorry but i dont know much about e30 cooling sencers(sorry for stupid Q's)
                            • rs4pro3
                              • 5808
                              no from the thermostat housing. There are 4 sensors there on eta's and two on I's one is the coolant temp, one is engine temp, one is Thermotime(for coldstart valve).
