I have an 89 e30 325i, thats having a weird issue.Every so often at the car would start to buck and would have small backfiring issues, loss of power like it was running out of gas and like it wasn't running on all cylinders. At first it was intermittent, and I couldnt narrow down the cause. Then it wouldn't occur for another month or so. I then realized this only happened at night. Now it occurs every time I put the headlights on. This only occurs when the headlights are on. In gear, its hard to get it to move over 20mph, but it its revs slowly in neutral.
I've replaced the fuel pump, did a tune up, swapped afm's, switched the o2 sensor. I'm assuming it's an electrical short.
Do any of you have any ideas of where I should start to look, or have you ever heard of an issue like this?
Thanks guys, I would really use some insight. My car is basically useless at night. With the change in daylight savings time, it's really frustrating.
