What other good maintenance items to toss into the e30...
  • dinanm3atl
    • Feb 2007
    • 7305
    So as some know I bought a pretty nice 2 owner e30 and working on maintaining to my standard and upgrading. I wanted to see if I missing anything as I did forget one item and it is not in my cart but if there are some others to pick up I will do that as well...
    Installed:
    IE3 Springs
    Bilstein Sports
    Front Strut Mount/Bearing
    Rear Shock Mounts w/ Reinforcement Plates
    Driver Side Wheel Bearing(PO Did Passenger less than 12 months ago)
    Tie Rod Assemblies w/ locking tabs and alignment
    *Previous Owner did Control Arms/Bushings less than 12 months ago*
    Waiting on Install:
    Front Brake Disc
    Front Brake Pads - Axxis Ultimate for Street Use
    Rear Brake Disc
    Rear Brake Pads - Axxis Ultimate for Street Use
    4x Brake Disc screws
    Front & Rear Brake Pad Sensors
    Center Support Bearing
    Guibo
    Z4 2.5i Lever
    Full Shifter Rebuild(Bushings/bearings/mounts/etc)
    5sp ZHP Weighted Knob
    Trans Mounts
    Waiting to Order:
    Sway Bars Front and Rear
    Strut Brace - Front
    Shock Tower Brace - Rear
    In Cart:
    Motor Mounts
    So what else should I grab while I am in there? I think at this point I have knocked out what I can remember! Anyone else want to say "Hey I would also do this..." fire away!
  • whiltebeitel
    • Apr 2007
    • 2098
    Timing belt/water pump if it's an M20. Make sure you put in reinforcements with those sway bars, rather have a little too much strength than a broken mounting tab.
    '89 325i track sloot
    '01 530i daily
    -Enginerd
    • dinanm3atl
      • Feb 2007
      • 7305
      Yah I will get those for sure.
      Already done the timingbelt/pump and all of that jazz. Has a fully rebuilt timing/ignition/plugs/etc.
      • whiltebeitel
        • Apr 2007
        • 2098
        Well, in that case, caber plates would nicely round out the suspension. If nothing leaks, it sounds pretty solid!
        '01 530i daily
        -Enginerd
        • dinanm3atl
          • Feb 2007
          • 7305
          No leaks and cold cold cold A/C ;)
          • whiltebeitel
            • Apr 2007
            • 2098
            /jealous.
            '01 530i daily
            -Enginerd
