i have to push start the vechile there is a spinning sound coming from the engine but no start. theres power. it could be the starter? i just bought one 8months ago
car doesnt start
I second the hammer idea. Give it a good whack and see if it wants to start then. If i does then you have a solenoid problem. If nothing happens still then it may be a powering issue at the key switch or starter relay.
Have a look and check back so we know everything is okComment
tap gently on the starter dont beat the mf'er up tho just gently while turning the motor over. if it starts then your starter is f'ed
either way its not too hard to replace
91 Apeshit Craze Godzilla powered s13:hitler:
86 Porsche 944
89 E30 325I
94 Mitsubishi Mighty Max
96 Ford Contour SVT
88 Honda Accord Hatchback
~Mike W.
If it is spinning freely, the strater motor is working. The solenoid pushes the starter gear to the flywheel, where it rotates the crank, starting the car. If the solenoid is good, there would be teeth missing on the flywheel.'89 325i track sloot
'01 530i daily
-EnginerdComment
I dont think the starter would spin at all if the solenoid was bad would it?
*No, it wouldn't*. That's why the hammer trick works, it's supposed to tap the shaft out, so it engages the flywheel. If the *bendix drive* doesn't work, the starter just free-wheels when the key is turned.'89 325i track sloot
'01 530i daily
-EnginerdComment
looks like you know what to replace now
+1
and take it back to where you got it get a new one(throwing through store window is optional):hitler:
(OO≡≡[][]≡≡OO) ///Motorsport
In this world, things aren't black & white. Its Delphin!
Parts, Buy Them--> http://picasaweb.google.com/transatl...eat=directlink
Snowboard & video game stuff --> http://r3vlimited.com/board/showthread.php?t=148645
Originally posted by Steve92E34Your car is breathing my air, and so are you.
AND you are both still slowComment
The starter would be stuck, The main purpose of the solenoid is a switch to turn the key power into the batter power.
Actually, you are right. The bendix drive would extend when the starter spins. The solenoid does exactly what you said. A broken bendix drive, could cause similar symtoms as missing teeth on the drive gear or flywheel.'89 325i track sloot
'01 530i daily
-EnginerdComment
