Oil pressure switch/sensor in M42 engine???
  • Gonzo318is
    • Sep 2004
    • 88
    Where is this located? I've ck'd the Haynes manual and although it mentions the switch/sensor in the troubleshooting tips I can't seem to find information on where its located and how to replace it.
  • e9nine
    • 1890
    • Gonzo318is
      • Sep 2004
      • 88
      Thanks e9nine So I assume pulling the switch is going to drain the fresh oil I just put in it last week?
      • e9nine
        • 1890
        NP. There is not that much oil in the bowl. With the car cold, .take out the filter, .leave a pan beneath the car, try pull out the switch gently...move on from there.
        • Gonzo318is
          • Sep 2004
          • 88
          Thanks, sounds like a quick and easy job.
          • Gonzo318is
            • Sep 2004
            • 88
            e9nine again thanks for the diagram... problem solved it was the oil pressure switch/sensor.
            • e9nine
              • 1890
              NP glad to see u fixed your problem
