Updated dyno info (EDIT w/ pics + Dyno VID)
  • Stu Mc
    • 4083
    Dyno'd my car during Santa Tech at Motorsport Connections last weekend, we wanted to get the a/f tuned with the right fuel pressure. We started it at 52psi and went from there, maximum power/torque and good a/f was realized at 58psi, so that is where it is now set. It now runs a little lean in the midrange and slightly fat on the topend. This is good for midrange punch, with it being a bit lean, and the topend has plenty of fuel and is safe to run at sustained high revs...no worries of premature internal wear.
    It pulled a solid 230whp with the fuel pressure set at 58pounds, torque was in the 215 range at peak. (edit: peak torque was just over 210 at the wheels, HP was about 235 at the wheels. The curves are much better than on my last dyno run (last December), where we ran 62psi (rich all over the place). It's making quite a bit more power all across the board, and the midrange throttle response/punch is a lot stronger.
    I'm about to go out with the stopwatch and time the 50-80, was about 4.1s with the old chip/62psi. (update: Getting high 3's with current setup, 3.8-3.9)
    Here is my graph:
    edit: 2 other cars dyno'd. An M30 6er with a Schrick cam and other goodies, he managed 202whp. A 3.2L M3 with Schrick Cam Kit, he pulled 225whp.
  • Stu Mc
    • 4083
    Getting 3.8-3.9 on the 50-80 now (3rd gear)
    • rwh11385
      lance_entities
      • 18403
      Awesome to hear Stu. I remember how poorly tuned your first dyno graph was. Scan for this one?
      • grapedrink
        • 1514
        Those are some nice number. ;)
        Originally posted by DaveCN
        Welcome.
        Your car is a piece of shit.
        Most of them here are, too.
        • Brew
          • 3060
          Wow, thats fast as hell. My car runs about 5.5 seconds 50-80 with the chip.
          '91 318is
          • Beau B
            • Mar 2004
            • 734
            What all do you have done to your S50? I am in the process of using your dad's kit to put mine in right now. Almost done :twisted:
            Beau
            1988 BMW 325iS
            • Stu Mc
              • 4083
              Robert, yea, fuel was a bit rich all over on my first dyno a year ago, but the main problem was a bad HFM, which has since been replaced. It made the curves extremely jumpy, new curves are much nicer. I should get them tomorrow.
              Brew, the big- bore big-stroke motors pull a lot harder in the mid and upper midrange, but the 2.5's still wax 2v's on the 50-80. I think my dad got in the 5's also in his 2.5 M50 318.
              Beau, Awesome, I hope the rest of your swap goes well. 3liter, right?
              Motor is built M50 with:
              3liter crank, pistons, rods
              Vanos head with M3 cams, late-model M lightweight valvetrain, milled head (~10.8:1 cr)
              Intake port work, heavy valve pocket work, 5-angle race grind, balanced/blueprinted...
              Euro MAF, knife edged throttle plate, OBD-2 SS manifolds, custom 2.5" exhaust, BMW NA Jim Blair 3liter chip, adj. FPR...
              Might have missed a few things
              • bmwannabe
                • 900
                I know its pretty "un R3Vlike" , but just for comparison, what type of 1/4 mile do you think you could produce?
                • Stu Mc
                  • 4083
                  Really not sure, but mid 13's would be a guess. I really don't like romping on the car that hard in a straight line though, and am steering clear of any sort of really heavy loads in 1st gear (half shafts and rearend have 250k+ miles). Traction is the issue holding the E30's back in the 1/4 mile, unless you can stuff enormous rubber and a rearend that will hookup
                  • Beau B
                    • Mar 2004
                    • 734
                    Yeah a 3liter, engine is in, so now we are just wiring it up. Those are some really good numbers for the mod's you have :twisted:
                    Beau
                    1988 BMW 325iS
                    • Stu Mc
                      • 4083
                      i have vids of my dyno runs, just need to have them hosted and placed in the thread.
                      • Stu Mc
                        • 4083
                        pics, big but whatever
                        • Tony S
                          • Apr 2004
                          • 88
                          Stu can the guys at Motorsport Connection burn custom chips on the dyno?
                          • Bryson
                            • 1490
                            :D
                            • Stu Mc
                              • 4083
                              Dyno Video. Run begins about half way through the vid, 4th gear.
