Sticky RPM
  • dpointt
    • May 2008
    • 8
    Sticky RPM
    Hi,
    Not too sure how to search for this one problem that is persisting...
    First of all, my ride just had a top overhaul, changed the fuel filter and timing belt within the last 6 months
    But here's the issue even after this overhaul done:
    when cold start, with air con compressor turn off; my rpm shows a 750 rpm
    even idling for 1 or 2 minutes later, I do get a sticky rpm
    here's the scenario, at 750rpm, it idles quite steadily...
    when I step on the gas, it will naturally goes up to 3000 or 4000 rpm (no prblem here) but when I release it, the rpm will drop to below 750 rpm, approx abt 600rpm then rise to abt 950rpm before stablizing at 750rpm again... not sure wat's its called, sticky rpm??
    Its gets pretty pretty low that it seems like the engine will just died w the red lights blink once or twice
    is this common for old cars? cos its sometime behaves quite normal without any problem (but its not often though) even after driving for a few miles, still have same symptom
    its less obvious with aircon turned ON but still get;s the same feeling and rpm is at 900...
    cos when changing the gears, I get lags with my manual transmission due to this problem!??
    Pls advise!
    That could be a sticky ICV, pehaps aggravated by small intake leaks.
    • AndrewBird
      The Mad Scientist
      • 11898
      I would look for vacuum leaks. Pull the accordion looking intake boot off and look at that. It often cracks between the folds and is hard to see unless taken off to look at.
      • dpointt
        • May 2008
        • 8
        hi guys, thanks for response...
        I had gotten tt replaced too even before the overhaul done
        FRL or ICV problem??? but so far car starts easily in the morning and no idling problem, or perhaps a little with no biggy issue encountered on it
        Other sticky suggestions?
        • dpointt
          • May 2008
          • 8
          gotten a rather new AFM yesterday
          had it replaced and not no more 'stickiness' from the engine and rpm on the odometer
          purrs like a kitten now!! heh...
