Top Nut of Koni Shock
    What is the size of the top nut on the front Koni insert? I think it is either a 21mm or 22mm. Either way, I cannot fit a normal size deep socket into the top strut bearing to see what size it is.
    TIA
    Aaron
    22mm
      Thanks much.
      Aaron
        My 22 mm impact was too thick to fit in the strut bearing, but my 7/8 inch deep socket fit fine. It is a tiny bit too large (0.2 mm) but works OK.
        Mike A
          Thank you. I just ground down a 22mm deep socket.
          Aaron
