My understanding of the starter solenoid conenctions is as follows:
Big +12v terminal - solenoid will contact this into the starter MOTOR circuit
2 little terminals - these are both grounds for little stuff.
Big Terminal already connector to starter motor...The starter itself is (somewhere) grounded to the block, which is in turn grounded to the chassis.
The question is - Can I add my own bigass ground from the Big ground terminal directly to Chassis to make sure none of the intervening connections are bad? I think you can do this by connecting directly to the outside of the starter motor as well.
Thoughts?
Ryan
Thoughts?
Ryan
