HELP bad compression test
  • havoxe30
    • Dec 2004
    • 46
    i have a 88 325is with 280k miles and it run good but it stumbles at idle and even when its hot it seems to get worse when its hot it feels like it is misfireing but it revs fine
    today id did a compression test and the results were
    1 = 120psi
    2 = 120psi
    3 = 130psi
    4 = 130psi
    5 = 130psi
    6 = 120psi
    i need help i dont know what to do or if i should just leave it alone or start looking for a new m20 and it has a bad valve tick and needs a timing belt is it worth doing the work and spending the money or should i just get a used motor
    and how much do they run
    i know a place in sac called attarco that my uncle got his m20 but i dont remeber how much ill call today
    1988 BMW
    325IS (E30)
    5 SPEED
    RED
  • Jordan
    • 12916
    lol... those compression numbers are fine for a 280k motor.
    Pay someone to adjust your valves and change your timing belt... it will cost like $300.
    https://mtechniqueabs.com/
    • Grant
      • Dec 2004
      • 526
      Re: HELP bad compression test
      Dont listen to Jordan. Those numbers are far too low. You need to buy my M20 ;)
      Grant Wescott
      1991 Sterling Silver 325iX stock (daily driver)
      1991 Black 325i stock (parts)
      "Eine Wurst, drei Größe"
      • havoxe30
        • Dec 2004
        • 46
        thanks for the info i was getting worried about it
        but it runs way to good to have something major wrong with it
        it just the valves can i just take it to any shop to have them done or should i just find a bmw machanic and pay him
        i might need an extra motor how much and what is the specs for your motor GRANT
        1988 BMW
        325IS (E30)
        5 SPEED
        RED
        • e30Matt
          • 5077
          Most competent shops can adjust valve lash and change timing belts.
          • mspiegle
            • 1026
            where in cali do you live?
            Michael Spiegle
            '01 Ford Escape / Daily Driver
            '99 M3 / Track Car
            '87 325is bronzit / wtf car
            '06 Daytona Triumph 675 / Daily Rider
            • havoxe30
              • Dec 2004
              • 46
              i live in south sacramento elk grove area do you or anyone know a shop they think is good or used before
              has anyone had it done how much did it cost
              thanks
              1988 BMW
              325IS (E30)
              5 SPEED
              RED
