i had a bad idle stumble when i got the car did everything cleaned everything but just wouldnt go away
so i was doing a compression test today and the plugs looked semi old so hay just replace them so i bought some ngk plat plugs and started up fine didnt pay much attention and i was at a stop light and i noticed no stumble yaaa
so i guess i should of just for got all the fancy stuff (afm,icv,o2c ) and just stick to the basics with idle stumble, plugs ,plug wires
whell it worked for me at least
also dosent hesitate when you step on it
