how do i remove my airbag steering wheel?
  • richardkeith97
    • 1693
    i have to replace my blinker switch and i guess i hafta take the steering wheel off. all i can find is stuff on how to take off a non airbag steering wheel. a little help would be appreciated. i want to pass inspection before i put my car away for the winter and this is the last thing i hafta do.
  • twistednut
    • Nov 2007
    • 272
    Disconnect battery
    Remove 2 torx screws that hold air bag to steering wheel (t20 IIRC)
    Unplug air bag
    Remove 22mm nut
    Insert key to unlock steering wheel
    Pull steering wheel.
    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
    • richardkeith97
      • 1693
      are the 2 torx behind the steering wheel?
      • twistednut
        • Nov 2007
        • 272
        yep
        • E30_fiend
          • Apr 2006
          • 7348
          you will feel two holes on the bac side of the steering wheel at the 3 and 9 o'clock positions.
