Building a car for track, AutoX and street, too and from the aforementioned.
I have a soggy engine mount I need to replace as well as the usual tranny mounts etc.
Owing to the fact that I have an 87is and am running the older cooling system this is obviously an item that needs to be addressed.
In my travels I came across these solid mounts from VAC
My questions are
1, Would a solid mount cause stress problems with the crossmember?
2, Would the compliancy in other driveline bushings such as the tranny mounts cause undue stress on the drive train?
3, would transmission mount's of a similar design be a viable option?
Also if anyone has experience with these or similar urethane mounts, I’d be interested to hear you feedback.
My questions are
