airbag woes
    airbag woes
    I took the airbag off my 92 318ic, no problem. However, when I reinstalled it, I screwed up the wire harness conector, and the wire coming fron the steering wheel pulled out of the connector.
    What is the proper routing of the wiring when reinstalling?
    If I replace the wheel with a non-airbag wheel, do I have to rewire the horn?
    Ditch the airbag, you don't have to rewire anything. You just need a non airbag wheel, and a spacer that I'm too lazy to look up for you.
    S54B32 swap in progress. Status: Getting There
      I am all for ditching the airbag, Will the horn work without connecting any wires?
        Yes.
        Moral of this story?
          sounds like a plan! thanks
            the wires are for the worthless airbag that I ditched on my car as well. The horn works off the brass slip ring on the back of the wheel.
            Gigitty Gigitty!!!!
