ive removed it from the car and am replacing the o-rings on either side and encountered a problem.
the original rings differ slightly from the rings that i have. On the original, if you take a cross section out of it, it would be a square. On the new o-rings , if you to a cross section of it, it would be a circle....do you see what im saying?
im just trying to make sure im using the correct o-rings!
