Damn Temp Guage
  • DEADZONER1
    • Dec 2004
    • 311
    Damn Temp Guage
    It doesnt budge, nomatter how hot the car gets. I replaced the thermostat and the water pump b4 i went to iraq a over year ago. The car wasn't driven except for july when i came home for a week. I need to know what sends the signal to the guage and tells it how hot the car is. Help, Its pissin me the kcuf off!
    https://farm8.staticflickr.com/7475/...1e97724413.jpg
  • DEADZONER1
    • Dec 2004
    • 311
    no ideas??? anyone?
    • nickmp0wer
      • 1427
      does it move a little when the cluster is powered up? its probably the sender
      • Court M3
        • Jan 2004
        • 6713
        Check to make sure the nut on the back is tight. 7mm IIRC that sometimes helps.
        On mine it was tight and since I had a spare gauge lying around I just changed the gauge and it worked fine
        Continuous For Sale Thread
        323i s50
        • bkelsey86
          • 1173
          Mine used to flop all aroud randomly and go all the way to red but if you tighten the nut on the back of the cluster it should stop false signals and such.
          • e30 dude
            • 67
            i got mine to work by tapping on the window breaker, as someone suggested.. stupid, i know, but it worked!!
            • BahnE30
              • 1050
              tap the dash above it
              have to do that to mine pretty much everytime i start the car, once it's up it works fine
              • DEADZONER1
                • Dec 2004
                • 311
                ok the emp guage moves a little when its powered up. when i shut off the car it rises a little and then shuts off normally. It never even enters the blue while driving. possibly the sender?
                TIA
                • almost_goth
                  • Dec 2004
                  • 23
                  Do you have a Bently book? I was reading up on the test for this problem earlier and it sounds like you can test to see if the problem is the sender or the gauge by running a jumper to ground from one of the leads on the sender. Want details?
                  • nickmp0wer
                    • 1427
                    yeah just take the connector for it off and get a screw driver and tap it to ground
                    • DEADZONER1
                      • Dec 2004
                      • 311
                      i was messing with it today. i took the connector off the sender and tapped it to ground. nothing happened. drove the car a few minutes later and the guage rose. soon after it got to temp the service indicator lights started flickering and the guage was bouncing all around. it did this a few times. any suggestions?
