Car running, runs like 4 cylinder diesal
  • E30godz
    • 1524
    i was running around with the car with about 3 feet of exhaust on it and it ran like shit...stupid slow and puttering, and i attributed that to the fact that there was no exhaust on it. Now i have exhaust on it and it runs the same.
    the idle is fairly steady and it will rev the 6500 but it goes like a 4 cylinder diesal....it takes forever, its heavily down on power. Keeping up with traffic is kinda difficult....sooo im not sure whats wrong? All the cylinders seem to be firing as i took off each wire to each cylinder while it was running and the engine started stumbling noticably each time.
    it also has a small vacuum leak on the AFM boot, but its been there and its never run this ....slow before.
    poor acceleration.
  • DEV0 E30
    • Oct 2004
    • 8894
    I had a hole in the 90 degree rubber boot that connects to the AFM, my car ran like shit because of it. I got some plastic posy stuff to seal it and it runs much better. I was so amazed a small slit in the rubber can make it run so poor. Get a tube of that plastic filler stuff, and fill the leak, my guess it will really make a difference. I guess the engine really needs to be tight where the flow of air comes from.
    • E30godz
      • 1524
      i dunno...ive sealed it up with dut tape and ive had worse vacuum leaks...this drop in power is phenominal...its like driving a 318i
      • 92 mtechnic cabrio
        • 4907
        oooooooooooo burnnnnnn :o
        R.I.P 07/01/09 - 04/23/10 :(
        • E30godz
          • 1524
          hahaha ; )
          • Dominick
            • Aug 2004
            • 323
            god i hate my m10, i need more power
            www.ThundaCats.com
            • E30godz
              • 1524
              hah one side of the injector clips came up causing it to fire sporadically, i fixed it.
              the car runs AMAZING...probably attritubted to the new head on there as well.
              • Dominick
                • Aug 2004
                • 323
                glad you found out what happened, enjoy your extra 2 cylinders
                www.ThundaCats.com
