I just got a cruise control system but the single blue/yellow speed pickup wire is cut. Which of the 4 pins on the cluster does this go? I do not have the green plug either so I'll have to pin it into the single hole.
Cruise control speed pickup wire on cluster
Tags: None
Just got the dash apart and it does have the green plug. I guess I'll just hook it up to the A terminal like the writeup says.Comment
The green plug has I believe 4 pins on it that go inside the cluster, now on the outside not ALL of the pins go to the same thing. You can use the DMM to verify this.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
