Alternator or Volt. reg?
    I've got 2 quick Qs for you guys.
    I've recently bought a 325IC and had issue starting the car on a damp day. After a quick check under the hood, I've found out the grounds where loose at the battery, and figured this is what caused the problem. Re-tighten, recharge the battery, next morning everything seems fine.
    I had a few doubts about the charging system though, so just to be sure, I've checked the voltage when engine is running.
    - idle gives about 13.25V
    - around 1000rpm goes up a tad over 14V
    - idle with headlights on drops at 13V / high 12V
    - around 1000rpm with headlight would be around 13.5V
    Reason I had doubts is that I can hear the heater fan speed drop when at idle. Never really noticed an intensity drop in the headlights though...probably because they are dirty as hell ;)
    So, the questions:
    - What would be the "acceptable" voltage range to expect on idle
    - Upon closer inspection, bosch voltage regulator on my alternator says 1197 311 021. Every catalog/website I've seen says the part should be 1197 311 027. Anyone can confirm this?
    I didn't knew much about e30's when I bought this one, and so far I've found the 325 IC to be somewhat the bastard child of the 325, so I wouldn't be surprised if the voltage regulator part number was different.
    Oh, and yes I'm a newbie. My name is Bjurr, and I drive a 1989 alpine white 325IC :)
    Thanks
      My voltage regulator doesn't have a part number on the back of it. How else can I tell which one I need?
      Thanks
      91 318is
        Thanks
        voltage looks good, the fan speed drops at idle on mine too
        1989 cirrisblau-metallic 325i
